Sorry but I would like to make some clarifications.
- the mobo already had the latest bios (f51m) and everything worked (with 1600x) .
Replacing the cpu ( to 3600x) made the pc not working.- the latest version (F51m) reports among other things "Fix AMD processor vulnerabilities security" and "Addresses potential UEFI vulnerabilities".
You might therefore think that it would be useful to update- given that the
3600x is supported from F40 version and upper (and I personally tested the F51d and it works), one might wonder what's wrong/or what they forgot in the F51m.
I can only put myself in the shoes of those who have only one processor available (let's say the 3600x), see a security update on the gigabyte site, update and find themselves with a non-working PC.
Luckily in my case I solved it. But how can you trust the quality of Gigabyte in testing before releasing a potentially "fatal" update?
ps. I don't remember the details now but in the past, a year after the release of this mobo, I had a similar problem. Since I too have been "tinkering" for many years I decided to give it a try: I bought the cheapest compatible processor (40 Euros or something like that. I still have it ...AMD A6
![Grin ;D](http://forum.giga-byte.co.uk/Smileys/default/grin.gif)
) and thanks to this I managed to start and restore the bios.
I wrote that just for chit-chat and share for those who find themselves unable to start their PC after an update, that this attempt (of putting a basic CPU) could grant them access to the bios again and then operate from there to put things back in order.
... and yes.
Do not upgrade your bios if you are not ready to (maybe) have some headaches
