p55m-UD2 not posting/no beep codes
draco
« on: May 28, 2010, 03:55:16 am »
 ::) here we go again
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.391813
theres the combo i bought
assembled everything, powered on, lights and fans turn on, hard drive spins, the DVD spins up...no post, no codes, not even a beep. nothing happens with the monitor until you power the system off, only then the monitor wakes up from sleep mode
i check all my connections, i tried using only one RAM stick, then both sticks in different slots, then the other single stick in every slot...no change
any more ideas?
slybunda
Re: p55m-UD2 not posting/no beep codes
« Reply #1 on: July 04, 2010, 01:27:51 pm »
ur link not working.
« Reply #2 on: July 04, 2010, 01:34:01 pm »
Correct, link is dead and says that the Combi deal is no longer available. Nice try though.  ;)
Could you post a few more details.....
in the mean time I assume you have tried the basics.......
There is a speaker attached to the Mobo so that you can hear any POST beeps?
You have connected all the power cables to the motherboard and, if necessary the graphics card?
You have double checked that everything is seated properly in the correct slots?
Your PSU has enough power to drive the full system?
« Reply #3 on: July 04, 2010, 02:02:49 pm »
Yes, not a lot to go on really ??? world's shortest post?
muliyul
  • 54
« Reply #4 on: August 06, 2010, 05:53:21 pm »
do you have a pc speaker connected/onboard? make sure its plugged in the right pins on the mobo.
It'd help if you'd supply us with specs.
