GA-G33-DS3R Can I use X16 PCIe slot for Raid Controller?
« on: September 19, 2010, 08:19:05 pm »
I have a server using a GA-G33-DS3R rev1.0 motherboard, I'm using the onboard graphics chip so the X16 PCIe slot is free.
Can I use the X16 PCIe slot for a SAS/Sata Raid Controller?  or can it only be used for Graphics Cards on this motherboard?
The raid controller I have in mind is the Supermicro AOC-SASLP-MV8, I know it's a low profile card, but I can get around that if it'll work with the motherboard's X16 PCIe slot.
Thanks for any input,
Mark.
« Last Edit: September 19, 2010, 08:41:58 pm by Suse User »
Re: GA-G33-DS3R Can I use X16 PCIe slot for Raid Controller?
« Reply #1 on: September 19, 2010, 08:24:10 pm »
Hi and welcome to the forum.
There is no reason why you cant use any card in the PCIE slot as long as it fits. Hope this helps.
« Reply #2 on: September 19, 2010, 08:27:39 pm »
Wow! thanks for the quick reply, I was reading a your response in another thread about a different motherboard/Raid combo but that didn't appear to be resolved.  I'll go ahead & order the card, thanks  ;D
Mark.
« Last Edit: September 19, 2010, 08:38:14 pm by Suse User »
« Reply #3 on: September 19, 2010, 08:29:03 pm »
I'm afraid your link didn't work so I couldn't check it.
That's better now you have modified it. ;)
« Last Edit: September 19, 2010, 08:42:53 pm by Dark Mantis »
« Reply #4 on: September 19, 2010, 08:41:13 pm »
Apologies, I've modified link in both my previous posts, the forums software doesn't need the "quotes" that other systems seem too,
Thanks,
Mark.
« Reply #5 on: September 19, 2010, 08:54:03 pm »
I checked the other post and that was a different story even though similar. I just checked the manual on your board and there is nowhere it says anything other then PCIE x16 which if it conforms to the standard then it will take any other PCIE card that fits.
