GA-M55SLI-S4 REV.1: Replacement Chipset Heatsink
« on: September 28, 2010, 04:25:03 am »
I was wondering if anyone knew a specific low profile chipset cooler or one that can get around a gtx260's without interference, and or the mm dimension of the 2 holes. Id like to have just a drop in replacement
Re: GA-M55SLI-S4 REV.1: Replacement Chipset Heatsink
« Reply #1 on: September 28, 2010, 11:00:49 am »
I think that you will find it a problem getting an active cooler that is of a lower profile than the one that is standard. I am not sure that even a watercooling block would be much better to be honest. :-\
Your only solution might be to use a passive cooler and have a remote fan blowing on it.
« Last Edit: September 28, 2010, 11:01:56 am by Dark Mantis »
