GA-H55N-USB3(rev. 1.0) HDMI
Re: GA-H55N-USB3(rev. 1.0) HDMI
« Reply #60 on: August 11, 2011, 07:01:21 pm »
hello now managed to do a better picture
« Reply #61 on: August 11, 2011, 08:37:51 pm »
That's a much better picture. It has definitely been caused by arcing. It is a shame that the motherboard has been returned as it would seem to be a bent pin that has caused the problem.
« Reply #62 on: August 11, 2011, 08:42:09 pm »
the machine is turned off for 10 minutes and after that it did not want to go, not even the fans. hut after the extraction was not inclined spike
« Last Edit: August 11, 2011, 08:44:16 pm by petko37 »
« Reply #63 on: August 11, 2011, 08:47:30 pm »
I am sorry I don't understand what you are trying to say there.
« Reply #64 on: August 11, 2011, 08:52:43 pm »
I'm sorry, google translator, the point is that the motherboard does not show anything
« Reply #65 on: August 11, 2011, 09:17:38 pm »
It would have to show a burnt pin at the very least as it couldn't do that damage to only one side of the connection.
