GTX 560Ti OC 2d / 3d profile problem
« on: May 19, 2011, 09:13:32 am »
Yesterday after cleaning drivers I have installed new graphic card on my computer Gigabyte GTX 560Ti OC model (GV-N560OC-1GI).
But after doing that I realised that something is wrong.
I normally use 2 LCDs 60Hz monitors (DualView in NVIDIA Panel) and when doing this my GTX 560Ti didn`t use 2d profile at all!
It stays always on high core clock, memory clock and voltage so it is getting worm even in IDLE.
 I tried NVIDIA drivers official 270.61 and beta 275.27 and noticed no difference.
Using two LCDs screenshot:
But when I switch to only one LCD everything is in order, card is going into 2d profile in IDLE, temperature is going down etc.
Using one  LCD screenshot:
What can I do to fix this problem? I don`t see any BIOS for this 560Ti card on the Gigabyte official site.
Re: GTX 560Ti OC 2d / 3d profile problem
« Reply #1 on: May 19, 2011, 02:48:55 pm »
Hi and welcome to the Gigabyte Forum.
If there is no other firmware that you can upgrade to then your options are severly limited for the moment. Obviously there is always the tweaking of the available settings but other than that I would advise contacting  GGTS and see what they can offer.
Just enter your email address and click on the language of choice.
GGTS   http://ggts.gigabyte.com/
Please expect several days for a reply.
« Last Edit: May 20, 2011, 01:19:21 pm by Dark Mantis »
« Reply #2 on: May 19, 2011, 10:45:17 pm »
I allready did.  :)
