RevoDrive x2 on a GA-X58A-UD3R
Aussie Allan
  • 1964
  • 141
Re: RevoDrive x2 on a GA-X58A-UD3R
« Reply #15 on: May 04, 2011, 09:57:07 pm »
          Update
  Couldn't resist before the weekend!  Had a wee play doing a simple install as the OS/Boot drive........Not quite performing as I'm sure it will end up!
  A couple of things that surprised me were, it indexed in windows at 7.9 but on AS SSD bench was reading @ 635Mb/s  but writing @ only 145Mb/s.....Huh!....and still gave me a 7.9!
 Toolbox will not recognise the drive so will not initiate.........my gut tells me I need to flash to 1.33 but the only Tutorial I can find (OCZ forum/support) uses a Big USB drive with Ubunti with the drivers loaded on...........bugger that!........I'm flat out coping with "Wundows".
 My intention tonight is to pop in a drive and load revo drivers and Windows to it as a boot and then reformat the revo/format/Flash from windows/rebuild back to Raid0 then bench again.....if it maxes out as it should...........reinstall OS to it and turn it back into a boot drive again........Wuddaya-think!
 Aussie Allan
i7-4790K @4.8GHz 24/7 water clock
MSI XPower AC
32GB corsair  2666Mhz
 GTX-1070Ti full cover
Lange DDC elite pump
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
6x2tb- raid5-Storage
C: Evo 970 Pro 512gb
Scratch:Evo 970 Plus 512gb
oggmonster
  • 659
  • 18
  • I can see Russia from my house
« Reply #16 on: May 04, 2011, 10:04:09 pm »
iirc 7.9 is the highest number you can get on Win7 index. Any idea why the write speed isn't what it should be?
There's no place like ::1
« Reply #17 on: May 04, 2011, 10:24:18 pm »
Yes the write speed is always much lower than the read speed but that is incredibly low.  :-\
oggmonster
  • 659
  • 18
« Reply #18 on: May 04, 2011, 10:25:52 pm »
Yeah swear their write speed in AS SSD was something along the 300mb speed?
Perhaps bios update?
Aussie Allan
  • 1964
  • 141
« Reply #19 on: May 04, 2011, 10:27:02 pm »
 The only thing I did very different was drop the strip size down to 32K just to see what if!  Won't really know until I can get into the toolbox me thinks!
 I've got the board throttled back to stock so there's no issues there although truth be told that was /is the first time I've used AS-SSD as well.......is there a better SSD benchmark out there that people like to use and is well recognised?
MSI XPower AC
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
oggmonster
  • 659
  • 18
« Reply #20 on: May 04, 2011, 10:29:11 pm »
On most of the revo x2 reviews ive seen AS SSD has been pretty much that shows up on 100% of reviews.
Aussie Allan
  • 1964
  • 141
« Reply #21 on: May 04, 2011, 10:29:50 pm »
 Mmmmmmmmmmmmmm! there's another quick question, ... When I do the flash do I do it once or does each unit (4) need to be flashed ??
 Aussie Allan
MSI XPower AC
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
oggmonster
  • 659
  • 18
« Reply #22 on: May 04, 2011, 10:30:58 pm »
Pass.. I was hoping you could answer all these questions so when (if) I eventually get one then you would have done all the ground work for me ;)
Aussie Allan
  • 1964
  • 141
« Reply #23 on: May 04, 2011, 10:32:20 pm »
  Dooh!
MSI XPower AC
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
« Reply #24 on: May 04, 2011, 10:33:17 pm »
I can't say I know either but I would have thought it would only be the once.
AS SSD is the recognised benchmark for SSDs.
Aussie Allan
  • 1964
  • 141
« Reply #25 on: May 04, 2011, 10:37:08 pm »
 Looks like I am in fact the Guinea Pig,  no probs ,...Ill keep you informed ... Oh yeh! ...I like Scotch!
Aussie Allan
MSI XPower AC
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
oggmonster
  • 659
  • 18
« Reply #26 on: May 04, 2011, 10:37:57 pm »
Aussie Allan
I'll see to it that you're well stocked on scotch... eggs ;)
Aussie Allan
  • 1964
  • 141
« Reply #27 on: May 04, 2011, 10:46:04 pm »
  Mmmmmmmm! Egg and Marvell chips!.........Nuther question Marster!!......Never though about it till now but the Windows 7-64 install took up a tad over 50GBs ,... does that sound correct........The 100GB Revo formatted down to 93GB to begin with.
MSI XPower AC
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
oggmonster
  • 659
  • 18
« Reply #28 on: May 04, 2011, 10:52:56 pm »
Ive used 49gb on my Win7 Pro x64, but about 15gb of that is games + other rubbish. You'll just have to be abit strict what you install!
Aussie Allan
  • 1964
  • 141
« Reply #29 on: May 04, 2011, 11:56:02 pm »
  I love the internet.........Apparently Sanforce and AS SSD don't  get along very well,  Numerous manufactures recommend ATTO!
 Have a look now ...and this is with no tweaking , bog stock setting and no firmware update as yet!!!!!!!!!!!!!!!!!!!  Aussie Allan ;D :o ;D
                      <a href="http://" target="_blank" class="new_win">http://</a>
MSI XPower AC
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
