GIGABYTE GA-Z68A-D3-B3 compared to GIGABYTE P67A-UD3-B3
« on: May 28, 2011, 12:58:19 am »
Hi all!
Just came here to ask for opinions on the differences between these two mobos:
GIGABYTE GA-Z68A-D3-B3 vs. the GIGABYTE P67A-UD3-B3.
I am presently using the GIGABYTE P67A-UD3-B3 but noticed the GIGABYTE GA-Z68A-D3-B3 on sale today for around $100.
Is it worth the upgrade?
Soar
AMD 1055T
GIGABYTE GA-990FXA-UD3
XFX 6870 DD
Corsair Vengeance 1600 16GB
OCZ ZX-850 Watt Gold
Intel i5-3570
ASRock Z77 Extreme4
GeForce 560Ti
CM HAF X Blue
Both Systems:
Windows 7+10
Scythe Temp Monitor + Fan Controller
Re: GIGABYTE GA-Z68A-D3-B3 compared to GIGABYTE P67A-UD3-B3
« Reply #1 on: May 28, 2011, 04:52:51 pm »
Hi Soar
There is very little difference between the two motherboards in essence. The Z68 has the new touchscreen BIOS which is really just another software add on apart from that there are not very many improvements in fact I was surprised to see that the Z68 board sports the old parallel and seriel ports again. I thought we had seen the back of them.
« Reply #2 on: May 30, 2011, 01:00:23 am »
Hi Soar
Ok, thanks, DM!
Soar
AMD 1055T
XFX 6870 DD
Intel i5-3570
ASRock Z77 Extreme4
GeForce 560Ti
CM HAF X Blue
Both Systems:
Windows 7+10
