Quickboost Missing from Easy Tune 6 on EP45-DS3L
AGD4
« on: September 20, 2009, 07:37:01 am »
Hi every1! I imagine this has been discussed already, but I've had no luck searching for a relevant post in the archive.
My issue is: After installing EasyTune 6 B09.0808.1 on my EP45-DS3L and restarting, I'm unable to see the 'Quickboost' mode in Easy Tune.
I'm running Bios revision F8.
I've installed EasyTune 6 on an EP45-UD3L and it seems to show Quickboost.
If anyone can assist I would greatly appreciate it.
« Last Edit: September 28, 2009, 02:45:47 pm by runn3R »
oggmonster
  • 659
  • 18
  • I can see Russia from my house
Re: Quickboost Missing from Easy Tune 6 on EP45-DS3L
« Reply #1 on: September 26, 2009, 02:31:48 pm »
Thats strange, is that the latest version of easytune? I used it on my EP45-UD3P withno problems whatsoever. Hopefully one of the Gigabyte guys can help you more  ???
« Last Edit: September 28, 2009, 02:45:38 pm by runn3R »
There's no place like ::1
runn3R
  • 1328
  • 57
  • Admin
    • GIGABYTE UK
« Reply #2 on: September 28, 2009, 02:44:08 pm »
Hi AGD4
First of all try to upgrade into the latest EasyTune6 ver. B9.0908.1 from our website:
http://www.giga-byte.co.uk/Support/Motherboard/Utility_Model.aspx?ProductID=2844#anchor_os
then use the latest bios version F10 as it can also help, file is here:
http://www.giga-byte.co.uk/Support/Motherboard/BIOS_DownloadFile.aspx?FileType=BIOS&FileID=14156
bios upgrade is best to be made using Q-Flash utility, the guide is located here:
http://www.giga-byte.co.uk/FileList/NewTech/old_motherboard_newtech/flashbios_qflash.pdf
If the above does not help please tell me what is your OS and provide screenshot of EasyTune without this Quickboost being active / seen.
