Hi DM
Thanks for the explanation, the words actually were NTLDR is missing, anyway I was using the CD to boot from and it asked if I wanted to repair, so I said yes and went through the process of reloading the OP again.
I have done a disc cleanup and the hdd is being defragged continuously,while the analysis says the disc is OK, and now when I boot I don't get the chattering and slipping noise and the PC seems OK, you have put my mind at rest with the thermostat news, and Core Temp now shows a temp of core 0 34% and core 1 @ 32% ish.
Thanks for your help, regards Robert.
