Less ram after bios update For GA-990FXA-UD3
« on: September 04, 2011, 02:41:26 pm »
Have a Gigabyte GA-990FXA-UD3 board and Windows XP Pro 64bit OS and have tried Windows 7 64bit...
both times it showed all 4Gb of ram.
Now after a bios update it shows only 3.99Gb out of 4Gb.....
Anyone have any idea why?
Re: Less ram after bios update For GA-990FXA-UD3
« Reply #1 on: September 04, 2011, 03:26:50 pm »
Hi there,
How much RAM is showing in BIOS?
You can check this either on the POST screen from a cold start (if you have disabled the Show Full Screen Logo) or by going to the BIOS home screen and pressing the F9 Key
« Reply #2 on: September 04, 2011, 04:36:15 pm »
At boot up it shows 4095 instead of 4096 of ram.
I even went back to an earlier bios but does not make any difference.
With  my old motherboard and any 64bit OS it showed 4Gb in windows.
« Last Edit: September 04, 2011, 08:19:24 pm by musicman53 »
