K8N-SLi PCI-e 2.0 gfx compatibility
« on: October 13, 2009, 03:41:16 pm »
Are the newer Pci--e 2.0 graphics cards compatible with this mobo? particularly the 9800gt or 4850 or 4870.
Badbonji
  • 356
  • 13
Re: K8N-SLi PCI-e 2.0 gfx compatibility
« Reply #1 on: October 13, 2009, 03:52:39 pm »
Yeah they will work just fine, only difference is 2.0 has 2x more bandwidth than 1.X, but nothing has even come that close to saturating the PCI-e 16x 1.x yet...
Core i7 965 @ 4.35Ghz 1.37Vcore
6Gb G.Skill 1600Mhz DDR3 @ 1740Mhz 8-8-8-20 1T
HIS HD5970 @ 800/1100
Gigabyte Extreme X58
X-Fi Xtreme Gamer Fatal1ty
256GB M4 + 150GB Raptor
EK Supreme HF/GTX480/MCP655/EK Res :D
« Reply #2 on: October 13, 2009, 03:54:25 pm »
oh that's a relief. Thank you.
