Gigabyte M61PME-S2 BIOS problem
Edo
  • 40
« on: October 14, 2011, 10:53:23 am »
Hello
Yesterday I have switched from Windows XP SP3 32 bit to Windows 7 Professional 64 bit.Now,when I try to enter BIOS it tells me that I have to install Xpress recovery 2.But,which driver should I install cause on installation CD I can't find any specific driver for Windows 7,only Vista 64 bit?
  • 5792
  • 527
Re: Gigabyte M61PME-S2 BIOS problem
« Reply #1 on: October 14, 2011, 01:07:36 pm »
Hi there,
I don't use Easy Recovery myself but I think you should be able to use the Vista 64 Driver.
