GA-EP45-UD3R will not boot - NEED HELP
Aussie Allan
  • 1964
  • 141
Re: GA-EP45-UD3R will not boot - NEED HELP
« Reply #15 on: May 14, 2011, 05:46:05 pm »
       Do YOU have ANY of THESE in the Tower, case, computer.........AA
i7-4790K @4.8GHz 24/7 water clock
MSI XPower AC
32GB corsair  2666Mhz
 GTX-1070Ti full cover
Lange DDC elite pump
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
6x2tb- raid5-Storage
C: Evo 970 Pro 512gb
Scratch:Evo 970 Plus 512gb
prioris
  • 11
« Reply #16 on: May 14, 2011, 06:29:58 pm »
I can't find where it explicit comes from but it always sounded like MB
Below are the specs for MB and chassis - so I have to figure audio beep is on MB
ANTEC 200 specs
CPU cut-out allows for easy installation of CPU coolers
Bottom-mounted power supply isolates heat and noise
Perforated front bezel delivers maximum air intake
Cable management compartment organizes cables discreetly
Front-loaded HDD cage for up to 6 hard disk drives
Cable management ties help keep your case tidier
10 drive bays:
- 6 x internal 3.5" HDDs
- 3 x external 5.25" HDDs
- 1 x external front-loaded hot swap 3.5" SATA hard drive caddy
7 expansion slots for plenty of flexibility
Cooling system:
- 1 x top special 140mm TwoCool™ fan
- 1 x rear 120mm TwoCool™ fan
- 2 x front 120mm fans for HDDs (optional)
- 1 x side 120mm fan for graphics cards (optional)
Front ports:
- 2 x USB 2.0
- Audio (AC'97 and HDA compatible) In and Out
Washable air filters for quick, easy cleaning
Maximum video card size: 11.5"/292mm (Note: some video cards may require removal of the adjacent hard drive cage)
Motherboards: Mini-ITX, microATX, Standard ATX
Power supply not included
Unit dimensions:
- 17.7" (H) x 7.9" (W) x 18.5" (D)
- 450mm (H) x 200mm (W) x 470mm (D)
Box dimensions:
- 21.3" (H) x 20.6" (W) x 11.2" (D)
- 541mm (H) x 523mm (W) x 284mm (D)
Net weight:
- 13.9 lbs / 6.3 kg
Gross weight:
- 16.8 lbs / 7.6 kg
Gigabyte GA-EP45-UD3R spec
General
    Product Type Motherboard - ATX
    Cache Memory None
    Chipset Type Intel P45 Express / Intel ICH10R
    Max Bus Speed 1600.0 MHz
    Processor Socket LGA775 Socket
    Max Processors Qty 1.0
    Compatible Processors Pentium Dual Core,
    Celeron 400 sequence,
    Celeron Dual Core,
    Core 2 Duo,
    Core 2 Quad,
    Core 2 Extreme
Memory
    Max Supported Memory 16.0 GB
    Supported RAM Technology DDR2 SDRAM
    Supported RAM Speed 667 MHz,
    800 MHz,
    1066 MHz
    RAM Features Dual channel memory architecture
Audio
    Type High Definition Audio (8-channel)
    Audio Codec Realtek ALC889A
    Compliant Standards High Definition Audio
LAN
    Network Controller Realtek RTL8111C
    Network Interfaces Gigabit Ethernet
    Modem None
Expansion / Connectivity
    Expansion Slot(s) 1.0 x Memory ( 1.8 V ) - DIMM 240-pin,
    3.0 x PCI Express x1 - LGA775 Socket,
    3.0 x PCI Express 2.0 x16,
    1.0 x PCI,
    4.0 x Processor
    Storage Interfaces Intel ICH10R : ATA-133 - connector(s): 2 x 7pin Serial ATA - 6.0 device(s) - RAID 0 / RAID 1 / RAID 10 / RAID 5,
    Serial ATA-300 - connector(s): 1 x 40pin IDC - 2.0 device(s) - RAID 0 / RAID 1 / JBOD,
    Serial ATA-300 - connector(s): 6 x 7pin Serial ATA - 2.0 device(s)
    Interfaces 1.0 x IEEE 1394 (FireWire) - Line-out (center/subwoofer) - Mini-phone 3.5 mm,
    1.0 x Audio - Generic - TOSLINK,
    1.0 x IEEE 1394 (FireWire) - Line-out (side surround) - Mini-phone 3.5 mm,
    1.0 x Network - SPDIF output - Mini-phone 3.5 mm,
    1.0 x Keyboard / mouse - Generic - Mini-phone 3.5 mm,
    1.0 x Hi-Speed USB - Floppy interface - RCA,
    1.0 x Audio - Ethernet 10Base-T/100Base-TX/1000Base-T - 34 pin IDC,
    1.0 x Audio - Line-out - 4 pin USB Type A,
    1.0 x Audio - SPDIF output - 4 pin FireWire,
    8.0 x Audio - Line-in - 6 pin mini-DIN (PS/2 style),
    1.0 x Microphone - Line-in - Mini-phone 3.5 mm,
    1.0 x Audio - Input - 4 pin MPC,
    1.0 x Audio - Line-out (rear) - 6 pin mini-DIN (PS/2 style),
    1.0 x Mouse - Mini-phone stereo 3.5 mm,
    1.0 x Storage - RJ-45,
    1.0 x Audio - 6 pin FireWire
    Additional Connectors (Optional) 4 x Hi-Speed USB,
    1 x IEEE 1394 (FireWire)
    Power Connectors 8-pin ATX12V connector,
    24-pin main power connector
Features
    BIOS Type Award
    BIOS Features DMI 2.0 support,
    ACPI 1.0b support,
    SMBIOS 2.4 support
    Hardware Monitoring Chassis fan tachometer,
    Chassis temperature,
    CPU core temperature,
    CPU overheating protection,
    System voltage,
    Power supply fan tachometer,
    CPU fan tachometer
    Hardware Features Q-Flash,
    Time Repair,
    Ultra Durable 3,
    Chassis intrusion detection,
    GIGABYTE Dynamic Energy Saver Advanced,
    DualBIOS,
    EasyTune6
Miscellaneous
    Cables Included 1.0 x Serial ATA cable,
    1.0 x IDE cable,
    1.0 x Serial ATA internal to external cable,
    4.0 x Floppy cable
    Software Included Norton Internet Security,
    EasyTune 6,
    Drivers & utilities,
    @BIOS,
    Q-Share
    Width 12.0 in
    Depth 9.6 in
« Reply #17 on: May 14, 2011, 06:32:02 pm »
+1 for trying Allan but the OP doesn't have a buzzer installed. You can often tell more from what you are not told than from what you are.
The reason for not hearing any beeps is that there is no device to emit them.
Prioris
I would advise you to install a buzzer and then we can move on from there.
Aussie Allan
  • 1964
  • 141
« Reply #18 on: May 14, 2011, 06:39:20 pm »
  Breath in......breath out.........breath  in ............
MSI XPower AC
G changer360 Rad x2
Phobya 450 balancer
W10 Pro-64
Zigor 2000 UPS
1x500GB for clone
prioris
  • 11
« Reply #19 on: May 14, 2011, 07:21:15 pm »
INSTALL BUZZER!!!!
you can't be serious
« Reply #20 on: May 14, 2011, 07:34:59 pm »
Yes, very much so. With a buzzer installed we might be able to make a bit more sense of the problem. ;)
prioris
  • 11
« Reply #21 on: May 14, 2011, 08:08:36 pm »
I may have to resort to bringing computer on monday to place that repairs computers to see if they can diagnose it since they may be more set up to plug and play with parts. I just want to make sure I did what I could do on my end.
« Reply #22 on: May 14, 2011, 09:11:13 pm »
Not being funny but that is probably the best idea as if you don't have much experience with computers it can get a bit over your head when trying to faultfind. Please let us know how you get on though. ;)
F5BJR
  • 478
  • 31
« Reply #23 on: May 14, 2011, 09:59:29 pm »
For test the good functionnaly of a motherboard you can with a minimum of components  :
Only Motherboard , CPU, Cooler , one memory stick in good place and
--> connect only a good PS2 keyboard
Start on , look the keyboard LED numlock normal is ON , push key numlock , look if LED numlock change to off
If that is OK stop and continue the test
If that is not possible you have a problem with CPU / RAM or Motherboard
Also test with another power supply
--> After
Use if possible an old VGA / PCI card ( because use few power ) , connect a screen
Start  if you have the BIOS on the screen --> GOOD
Continue with your PCI-E VGA card  ....
Reinstall the others devices one by one ...
Pierre
« Last Edit: May 14, 2011, 10:13:28 pm by F5BJR »
GA-X58A-UD5 I7 930
6x2Go KINGSTON 9905403-084
ENERMAX Modu 82+
Sharkoon REBEL12
2*HD5770SingleSlot+PCI-HD4350
2xSENSY 26'
2xBOX 5HD HotPlug
3xBOX 34HD MaxinPower
2x AD4SR5HPMU Addonics 8x1ToWDGreen
4x 1TO RAID10 ICH10+1 BACKUP OS
2 * RR622 HighPoint
Sata 88SX7042
AverMedia H727
prioris
  • 11
« Reply #24 on: May 14, 2011, 10:28:08 pm »
will try that later on
