Need Help Please
803dh1
Need Help Please
« on: October 16, 2013, 08:02:33 am »
Need Help Please
i have problem like this 4GB RAM installed, only 2GB usable? Windows 7 64-bit
my komputer Spek
cpu i5 750
gigabyte p55 ud3l
his radeon 5670 128bit 1gb
hdd 360gb
psu venom rx pure 500watt
memory ddr3 corsair vengeance 2x2gb
OS Windows 7 64bit
try install a different one memory its detected 2gb,try install another one it detected 2 gb
if both are installed its 4GB RAM installed, only 2GB usable
one by one, I've checked the memory chip using a memory diagnostic tool and the results are good
803dh1
Re: Need Help Please
« Reply #1 on: October 17, 2013, 03:21:34 am »
803dh1
« Reply #2 on: October 17, 2013, 03:22:15 am »
803dh1
« Reply #3 on: October 17, 2013, 03:22:48 am »
  • 3093
« Reply #4 on: October 17, 2013, 03:38:32 am »
Have you gone into msconfig / boot / advance option and make there isn't any check marks on the CPU and Memory.
803dh1
« Reply #5 on: October 18, 2013, 07:30:29 am »
Yes i have uncheck MEMMAX
