Buying Advice Needed
Ramer
« on: February 04, 2014, 03:51:40 pm »
I'm getting ready to build a new computer which I haven't done in a few years and I'm hoping someone can tell me if the following setup is compatible.
http://www.amazon.com/Gigabyte-Intel-DISPLAY-Motherboard-GA-Z77-HD4/dp/B00APZXXWC/ref=sr_1_10?s=electronics&ie=UTF8&qid=1391455316&sr=1-10&keywords=Gigabyte+LGA+1155
http://www.amazon.com/Intel-Core-i5-3470-Quad-Core-Processor/dp/B0087EVHVW/ref=pd_sim_pc_4
I already have 8 gigs of this memory: Corsair XMS3 4 GB 1333MHz PC3-10666 240-pin DDR3 Memory CMX4GX3M1A1333C9
I'm also planning on getting this monitor: http://www.amazon.com/Dell-27-Inch-Touchscreen-LED-lit-Monitor/dp/B00F86RO96/ref=sr_1_2?s=pc&ie=UTF8&qid=1390925807&sr=1-2&keywords=touch+screen+monitor and using the DisplayPort. Will I be able to use a second monitor using DVI-D?
Thanks for the help  :)
  • 3084
Re: Buying Advice Needed
« Reply #1 on: February 04, 2014, 07:15:19 pm »
Everything looks good to go on your parts. This is from the book:
Dual Display Configurations for the Onboard Graphics:
This motherboard provides four video output ports: D-Sub, DVI-D, HDMI, and DisplayPort. Dual monitor
configurations are supported in operating system environment only, but not during the BIOS Setup or POST
process
Ramer
« Reply #2 on: February 04, 2014, 09:49:07 pm »
Thank you, I'm looking forward to the upgrade :)
