ga-970a-ud3 Rev 3.0 bios update FDe
fadsarmy
  • 167
« on: March 28, 2015, 09:27:33 pm »
I just flashed Fc bios to FDe in preparation for 8370. I'm currently using Phenom 965. It keeps prompting me to load bios defaults everytime I start/restart computer. I reflashed back to Fc and all is okay again but it doesn't support my new cpu. Any ideas?
  • 3093
Re: ga-970a-ud3 Rev 3.0 bios update FDe
« Reply #1 on: March 29, 2015, 12:39:07 am »
When you flash the bios are you shutting it down pulling the battery and clearing the cmos?
  • 3093
« Reply #2 on: March 29, 2015, 12:45:51 am »
If you are having problems with the bios update just get FX-8350? The two are the same other than the price.
http://www.cpu-world.com/Compare/313/AMD_FX-Series_FX-8350_vs_AMD_FX-Series_FX-8370.html
