Windows 10 crashed GA-H81M-DS2, while Linux does not.
« on: June 03, 2019, 06:14:16 am »
In 2018, Windows 10 crashed my GA-H81M-DS2 repeatedly. For details, see http://www.tenforums.com/drivers-hardware/122708-hardware-problem-has-nothing-do-windows.html
On January 1, 2019, I replaced Windows 10 with Linux Mint. Since then, Linux has not crashed my GA-H81M-DS2.
Are there other GIGABYTE users who have their motherboards crashed by Windows 10?
« Last Edit: June 03, 2019, 06:17:47 am by Matthew Wai »
  • 2243
Re: Windows 10 crashed GA-H81M-DS2, while Linux does not.
« Reply #1 on: June 04, 2019, 03:30:48 pm »
Glanced at your other thread.  You have nothing which is definitive, but appear to have a stable system with another install or OS.
What does that tell you?
>Software, hardware or combination of the two
Install, Driver, Update, BIOS setting or combination of all.  We can't speculate and neither can the people in the other thread.  I will say one thing however, I don't think you need to replace your CPU and RAM as one person suggested.  Your system is running, right.  No problems with Linux.
Some software / hardware configurations don't work perfectly or well together.  A manufacturer cannot test or certify every scenario. Was your windows install from scratch, or did you migrate from the failed Asus MB?
Your issue is described as a "malfunction".  What is that exactly?  Did you review the Event Logs for additional/possible error information.  Was the behavior consistently reproduceable?  Every time I do A, B, C, (these steps), this is the result?
What troubleshooting steps did you try or perform?  There are so many unanswered questions.  Which only leaves people with the ability to guess.  Not a reliable way to help.
If you don't have the windows install any longer, its pretty much a mute point.  You have nothing to reference, and no way to troubleshoot or reproduce the issue.  All you can hope for is conjecture or speculation.
