Newly Built PC
Etype
Newly Built PC
« on: June 16, 2020, 07:11:58 pm »
Just built a PC and will not boot. After start screen it goes to a black screen that says "Detecting Array", when I only have 1 HDD. Using the old IDE. SYSTEM: Motherboard is Gigabyte GA-m68m-s2p
CPU is AMD Athlon II,Bus speed: 667 mhz,voltage: 0.925 - 1.425
RAM is DDR2 1066 MHZ, 2 GB sticks
Onboard video card is NVIDIA GeForce 7025,NVIDIA nforce 630 a GPU
HDD: WD 320 GB IDE
Can someone help?
  • 1958
  • 63
Re: Newly Built PC
« Reply #1 on: June 17, 2020, 04:16:48 am »
HDD: WD 320 GB IDE
Can someone help?
See page 40 of your manual:
https://download1.gigabyte.com/Files/Manual/mb_manual_ga-m68m-s2p_e.pdf
Suggest you disable SATA RAID Config, NV SATA RAAID [Disable]
Save and retest.
Z390 AORUS PRO (F10) \850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 2080 FTW3 Ultra, 960 Pro_m.2, W10 1909
Z370-HD3P (F5) \750w, 8350K, 8GB LPX 3200 - 16-18-18-38, GTX 970 FTW SC, Intel SSD, 2TB RAID1, W10 1909
Etype
Re: Newly Built PC
« Reply #2 on: June 17, 2020, 04:26:27 pm »
Did that already. Is there anything else short of buying another motherboard?
  • 1958
  • 63
Re: Newly Built PC
« Reply #3 on: June 18, 2020, 03:46:59 pm »
I'll take a quick peek at your manual again.  It would appear that RAID is enabled somewhere if the BIOS or legacy utility is looking for disk members.
Are you sure you don't have RAID enabled somewhere?
It's an 11 yr old board and not BIOS since 2013.  Not sure how much time you want to spend on this.
Etype
Re: Newly Built PC
« Reply #4 on: June 18, 2020, 11:34:46 pm »
Nv SATA Raid function;
 Nv SATA 1 Primary;
Nv SATA 1 Secondary;
Nv SATA 2 Primary;
Nv SATA 2 Secondary all are disabled. If there is a way to make it work that is what I'm looking for. If not I'm ready to move on.
