Upgrading part of my system
cookiebun
  • 163
« on: July 03, 2020, 04:15:15 pm »
Hi I am hoping to upgrade my present system,
Intel Core i7 8700K Unlocked Coffee Lake OEM CPU/Processor
AORUS Gaming 7 Intel Z370 (Socket 1151) DDR4 ATX Motherboard
Corsair 32GB ( 4x8) DDR4 Vengeance LPX 3000MHz Memory
Zotac NVIDIA GeForce RTX 2080 8GB AMP! Extreme Turing Graphics Card
Samsung 970 EVO PLUS 500GB M.2,   Samsung 970 EVO Plus 1 TB PCIe NVMe M.2
ASUS ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor
NZXT Phantom 410 Black Orange Special Edition
Sound Blaster X AE 5 RGB PCIe Gaming Soundcard
Corsair RM1000
Roccat ROC-11-812 Kone EMP Max Performance        Razer Basilisk x Hyperspeed Wireless Gaming Mouse
Roccat isku/ fx
Windows 10 Home 64-bit
with
https://www.scan.co.uk/products/intel-core-i9-10900k-s-1200-comet-lake-10-cores-20-threads-37ghz-53ghz-turbo-20mb-cache
https://www.scan.co.uk/products/gigabyte-aorus-master-intel-z490-s-1200-ddr4-sata3-3x-m2-sli-crossfire-25gbe-ax-wifi-bt51-usb-32-gen
https://www.scan.co.uk/products/cooler-master-masteair-ma410m-single-tower-cpu-cooler-4-heatpipes-2x-120mm-rgb-fans-addressable-rgb?gclid=EAIaIQobChMIs7Dgv7WH6gIV2cqyCh2o_gN4EAYYASABEgLfnfD_BwE
Is the new cpu cooler compatable and is my ram and the rest of my stuff compatible.
  • 2964
  • 37
Re: Upgrading part of my system
« Reply #1 on: July 03, 2020, 07:29:22 pm »
I have build 2 on the new socket. Everything is compatible with the new socket. Other then the CPU. On the cooler they haven't change the holes from 1156. They have been the same for all of them. 1156, 1155, 1150, 1151 and now 1200.
Plus one other thing is all CPU's are now Hyper threading i3, i5, i7 & i9.
« Last Edit: July 03, 2020, 07:32:41 pm by dmdilks »
GIGABYTE-GA-X299-UD4, i9-7900X 3.30GHz, ADATA XPG Z1 32GB DDR4 2400 Quad, RX-590-8GB, In Win Glacier 900W, Cooler Master HAF 932, 1-240GB SSD sata-3, Win7 Ult-64bit, 1-M2-NMVe SSD-512gb Win 10 pro 64bit, 40" 4k TV
cookiebun
  • 163
« Reply #2 on: July 03, 2020, 11:54:05 pm »
So am I right to understand all is compatible and good to go even the ram, the only thing I need to check is whether there is enough clearance in my case for the cooler.    regards
 the hyper threading does that make any real difference.
  • 2964
  • 37
« Reply #3 on: July 04, 2020, 01:02:25 pm »
I feel that Hyper threading is only good when you doing a lot things at the same time. For years it didn't really help in gaming.
But yes you are good to go on everything. I have found that some older video cards do run on them. But you will have problems with booting & in windows. To run a older video cards you have to disabled CSM to get them to boot. The older cards have some problems going into sleep mode and coming out.
I have tried RX-580 & 590 cards and gave me boot problems. Those cards run GDRR5. But your video card should be fine it runs GDDR6. I have two cards with GDDR6 and they run fine.
cookiebun
  • 163
« Reply #4 on: July 09, 2020, 11:55:31 pm »
Just one last question would the cpu cooler I am currently using be good enough for the new processor it is a
Coolermaster Hyper T4 Intel and Amd Socket Heatpipe Cooling Fan
  • 1938
  • 60
« Reply #5 on: July 10, 2020, 03:37:12 pm »
Yes, the T4 supports LGA1200.
https://www.coolermaster.com/catalog/coolers/cpu-air-coolers/hyper-t4/#:~:text=Hyper%20T4%20Hyper%20T4%20is%20a%20budget-conscious%2C%20direct,fine%20tuned%20for%20excellent%20airflow%20and%20cooling%20performance.
It not a high end cooler, but can work.  Good static pressure and a quality case with good airflow will further contribute to your success.  If your plan is to OC, this may not provide the amount of cooling you might need.
Z390 AORUS PRO (F10) \850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 2080 FTW3 Ultra, 960 Pro_m.2, W10 1909
Z370-HD3P (F5) \750w, 8350K, 8GB LPX 3200 - 16-18-18-38, GTX 970 FTW SC, Intel SSD, 2TB RAID1, W10 1909
