Aorus RTX 3080 Master RGB Fusion 2.0 fault
« on: January 19, 2021, 08:09:43 am »
Hello, I have a fault with the RGB Fusion software. When I load it up all I see is what you can see in the screen shot. Because of this (I think), the small screen on my GPU doesn't display anything correctly. Right now all I can see are gifs of the hawk thing on repeat but I want to be able to see my FPS and GPU Temp. I have attempted to uninstall the RGB Fusion software and reinstall it but I get the exact same screen.
Can anyone suggest a fix for this please?
Re: Aorus RTX 3080 Master RGB Fusion 2.0 fault
« Reply #1 on: January 19, 2021, 08:11:06 am »
Does this site not allow screenshots from IMGUR? What upload sites can I use?
« Reply #2 on: January 22, 2021, 02:03:38 pm »
Wow! The official support forums are amazing, 3 days with zero response.
« Reply #3 on: January 25, 2021, 04:22:05 pm »
6 Days
« Reply #4 on: January 29, 2021, 07:01:08 am »
You don't read manuals? Install AORUS ENGINE app mate.
« Reply #5 on: February 02, 2021, 09:51:54 am »
I have installed the Aorus Engine, I installed it the second I installed the card. The Engine application works fine, the problem if you choose to read, is with RGB fusion, not Aorus Engine.
« Reply #6 on: February 02, 2021, 10:01:49 am »
But just to appease you, I've fully uninstalled both RGB Fusion and Aorus Engine, reinstalled Aorus Engine (which then installs RGB Fusion) and I get the exact same fault.
https://imgur.com/4el6PgJ
This is a link to the screen I get seeing as I can't post images here.
  • 2258
« Reply #7 on: February 03, 2021, 03:32:52 pm »
Need to see an example of the issue you are experiencing.  Imgur works fine.
I see your link now.
That's something software related.  Either the version of fusion you installed or something to do with your OS or environment.
What files are you using for install?
Update: Note.. v1.96 was released yesterday
https://www.gigabyte.com/Graphics-Card/GV-N3080AORUS-X-10GD/support#support-dl-utility
« Last Edit: February 03, 2021, 03:50:04 pm by shadowsports »
« Reply #8 on: February 05, 2021, 11:16:56 pm »
I'll try that new install but I was just getting the latest version of Aorus Engine from the Gigabyte downloads page and installing that.
« Reply #9 on: February 05, 2021, 11:24:21 pm »
OK I've used that new version and get the exact same fault.
  • 2258
« Reply #10 on: February 06, 2021, 03:56:37 pm »
I suggest you get a ticket opened with support:
https://esupport.gigabyte.com/Login
If you've tested with two versions of the software and still have the same result, they can probably help.
I'm also seeing v1.97 now.
« Last Edit: February 06, 2021, 04:03:35 pm by shadowsports »
