Latest Realtek Sound Driver
teknology9
  • 713
  • 31
« on: October 09, 2021, 05:19:25 pm »
I am trying to install the latest Realtek sound driver for my motherboard but it will not install as before. Instead it goes around in a loop. The install shield keeps asking do I want to reboot my PC now or later.
I have  uninstalled the previous driver and thought it would be a straight forward install, any ideas folks?
Windows 10 Home
Version 21H1
Update:
Realtek HD is showing in Device Manager but the icon does not show in Program & Features for some reason. Nevertheless I now have sound.
teknology9
« Last Edit: October 09, 2021, 05:57:08 pm by teknology9 »
Windows 10 Home Edition
NZXT Phantom
Seasonic Platinum 1000w
Noctua NH-U12P SE2
Corsair 16GB 2666
Gigabyte B460M AORUS PRO
MSI GeForce GTX 1650 D6 Gaming X 4G
i5- 10400
Samsung 970 Evo Plus - 250GB
Samsung 830 SSD - 250GB
PC building.........it's no fun if it's easy!!!
  • 3069
Re: Latest Realtek Sound Driver
« Reply #1 on: October 10, 2021, 12:22:31 am »
Have you tried to reboot because it might be like Ati drivers. When windows loads the drivers for most everything. Ati drivers will always ask to reboot before installing the new driver.
I don't worry about drivers on a computer. Since windows 10 does everything for you. Plus if everything is working leave well enough alone. The only driver I will install is the graphics driver. That is most likely when I first installed windows too.
My video driver is 3/2021, sound driver 9/2020, & Network driver 9/2019.
So if you got your sound working that is good. I as always say "If it isn't broke don't fix it" LOL
« Last Edit: October 10, 2021, 12:24:02 am by dmdilks »
teknology9
  • 713
  • 31
« Reply #2 on: October 10, 2021, 10:07:13 am »
Yes, I have tried to reboot as per instructions on the install shield. It then takes me back to the install shield and then the same options appear for a reboot now or later on.
The driver is for both Windows 10 and 11. Yes it's working but no icon appears in Program & Features.
Thanks for the reply.
teknology9
NZXT Phantom
Noctua NH-U12P SE2
Corsair 16GB 2666
i5- 10400
  • 3069
« Reply #3 on: October 10, 2021, 11:26:58 pm »
For the hell of it I installed the realtek sound driver 9/2019. I had a Microsoft driver and it was really newer 9/2020. It installed with no problem and it does have a icon in the Programs & Features.
I have the Ga-x299x-aorus-master board. I'll have to check my GA-Z490 Vision G and what that has for a driver.
« Last Edit: October 10, 2021, 11:28:03 pm by dmdilks »
  • 3069
« Reply #4 on: October 10, 2021, 11:41:03 pm »
OK Just check Ga-z490 Vision G and the driver is realtek. But it is a older driver 1/2020. Now the thing is I'm still for some reason running version 2004 on windows 10. LOL
What version windows you running? I tried to install the newest driver and it is telling me to uninstall the old driver and reboot.
teknology9
  • 713
  • 31
« Reply #5 on: October 11, 2021, 07:54:59 pm »
The Windows 10 version I have installed is version 21H1. I uninstalled  the old driver first from  B460M AORUS PRO (rev. 1.0) motherboard and then what happened afterwards is as stated above.
Thanks,
teknology9
NZXT Phantom
Noctua NH-U12P SE2
Corsair 16GB 2666
i5- 10400
Banton
« Reply #6 on: December 03, 2021, 04:22:11 pm »
I had this exact problem, I think, where the uninstall was continuously looping. You have to fully uninstall your audio yourself, remove the software install and the drivers from control panel / device manager and if you can prevent it trying to install auto on reboot, you will be able to properly install the drivers you are having the loop issue with. I googled the issue and found the answer (not being sarcastic) after a bit of digging. I don't remember which gave the exact method sorry but it was generally this.
I am having a sound / echoing crackle that fades on when enough sound hits the sound card. I tried this, no solution yet.
« Reply #7 on: December 04, 2021, 02:56:07 pm »
Its likely that going back one or two driver versions will not exhibit this looping install behavior.
I have sound drivers on one machine W10 21H1 from 2014.  They are working perfectly.
Intel 2016
RealTek 2014
nVidia 2021
« Reply #8 on: December 19, 2021, 08:11:47 pm »
the latest Realtek audio driver is 6.0.9235.1 dated 9/6/2021 from gigabyte's web site.
works with recent & older Gigabyte boards, even with my Gigabyte board running Win10 21H2
« Last Edit: December 19, 2021, 08:13:19 pm by erpsir1 »
« Reply #9 on: January 02, 2022, 09:23:03 am »
I have had this problem with the installation loop on Windows 11.   After informing Gigabyte I think a new update was added as it was quickly fixed but with Realtek no longer adding support for 5.1 sound I wanted to know if there is software or if they still make PCI soundcards that support the 5.1 format?
What Realtek have done is made having a great sound setup pointless as you can now only get 2.1 sound no matter what your setup is.
« Reply #10 on: January 12, 2022, 08:34:51 am »
I managed to fix this problem by uninstalling the drivers and the registry entries but wanted to know if anyone else has this problem or if it is covered somewhere else?
I have the Aorus Ultra Z390 and the only audio options I get are 2.1 sound and no 5.1.
I have the Logitech z906 5.1 speakers connected through S/PDIF.
If as I have been told, Realtek no longer offer support for 5.1, is there a work around or alternative or should I just install a sound card as the sound on Aorus motherboards is no longer super doopa as we are led to believe?
  • 3069
« Reply #11 on: January 12, 2022, 03:07:58 pm »
#1 if you don't want windows to install any drives disconnect from the internet.
#2 What I would do is let windows to install the sound driver. Then install the realtek driver over the one that windows has put in.
#3 The thing is people get to bent out of shape on stuff like this. If I worried about the small stuff on drivers on my computer I wouldn't be enjoying it. 80% to 90% of my drivers are out date. If I'm not having any problems, I don't update.
« Reply #12 on: May 20, 2022, 12:47:58 am »
latest Realtek audio driver is 6.0.9287.1 released early Feb. 2022 although it was listed for recent aorus/aero laptops but also works on recent Gigabyte boards as well.
and yes, before installing or uninstalling/removing Realtek audio driver, disconnect from the internet.  then after installing or updating to new driver and rebooting, reconnect to internet.
Gigabyte seems to only put that little "disclaimer" for the realtek audio driver download for recent AORUS/AERO laptops such as aorus 17x 12th gen intel only but not for motherboards
Realtek High Definition Audio
please install the audio driver, after disconnected the internet.
« Last Edit: May 20, 2022, 12:50:46 am by erpsir1 »
« Reply #13 on: March 29, 2023, 05:19:00 pm »
new realtek audio drivers from Gigabyte
version 6.0.9468.1 for recent 2023 gigabyte aorus/aero laptops (released late March 2023)
version 6.0.9373.1 for recent gigabyte boards (might work with boards with certain older intel & amd chipsets like z490, x470, etc.) - released late 2022
