RTX 2060 OC rev 2.0 fan rattle issue
« on: November 28, 2021, 09:46:41 pm »
I've had my RTX 2060 OC REV 2.0 form gigabyte for a bit over a year now and from about 3 months ago the fans have been rattling or making a sort of grinding noise whenever they're spinning fast. I've contacted gigabyte's support page about this but they've been doing very little for over a month now. Is there anything that can be done about this?
  • 2237
Re: RTX 2060 OC rev 2.0 fan rattle issue
« Reply #1 on: November 29, 2021, 02:30:43 pm »
Warranty coverage varies by region and I'm not sure where you are located, but GPUs typically carry a 3 yr warranty to the original owner with proof of purchase and registration.
https://member.aorus.com/global/productwarranty
https://ggcs.gigabyte.com/GIGABYTE-RMA-Login-User.aspx
« Reply #2 on: November 29, 2021, 02:37:11 pm »
Yes, that's why I've contacted them but they've just told me to go to the place I bought it from who's warranty has run out. They also take 3 weeks to respond each time I send something in response to them.
