RGB Fusion 2.0 not applying on startup
« on: May 20, 2022, 09:51:50 pm »
Since I upgraded to Windows 11, every time I turn the computer on, the Gigabyte logo on my RTX 2060 super gets static. Even if I set RGB Fusion to startup with windows on system tray, it won't work until I actually open the app.
I already did a fresh windows 11 installation and it didn't solve it.
  • 2237
Re: RGB Fusion 2.0 not applying on startup
« Reply #1 on: June 16, 2022, 01:56:37 pm »
I didn't see the RTX2060 on the list of supported cards - RGB Fusion 2.0 site, however, its part of the Aorus Engine downloads on the cards support page, so it must be supported.  Yours appears to be a windows 11 issue.
What programs do you have set to run at boot time?
Have you tried support?
https://www.gigabyte.com/us/Support
« Reply #2 on: June 28, 2022, 06:39:03 pm »
Yes, it's supported, it has always worked.
It's Aorus Engine, every time it starts, the LED gets static, I need to open RGB Fusion to fix it. If Aorus Engine doesn't boot, the problem won't occur.
