BIOS versions for GA-H67MA-UD2H-B3.
IsLNdbOi
  • 26
« on: March 16, 2011, 10:33:13 am »
I finally got my GA-H67MA-UD2H-B3 rev.1.1 installed.  During boot AND when I go into the BIOS, I see that my BIOS version is F1.
I went to the Gigabyte website to check for an updated BIOS and found F2.  However, F2 is listed as the initial release BIOS for my motherboard.  Do I have some kind of pre-release motherboard since the BIOS is lower than the initial release BIOS?
Lsdmeasap
  • 1166
  • 58
    • Gigabyte Support (TweakTown USA)
Re: BIOS versions for GA-H67MA-UD2H-B3.
« Reply #1 on: March 16, 2011, 10:41:56 am »
Ya that's all it is, and basically no reason for them to post up F1 because everyone has it already.
« Reply #2 on: March 16, 2011, 12:25:19 pm »
Yes you can update to F2 BIOS version if you need to but I doubt that there is much difference. It doesn't actually list any fixes so there is nothing important in it.
dimmy32
  • 16
« Reply #3 on: March 16, 2011, 12:30:09 pm »
Good to know...I was wondering the same thing :)
