X58A-UD3R ver2 BIOS problems
fatbobuk
  • 73
« on: August 20, 2010, 06:02:09 pm »
Have been having major problems with this board
With delivery BIOS FA ran and overclocked great except for disappearing RAM 6Gb with 4Gb usable
BIOS FB11 Beta ran very very slow on boot up if it booted at all and couldnt access overclocking options
SO returned to FA
BIOS FB16 Beta exactly the same as FB11 but after a lot of grief and aggro and about 2 hrs it eventually booted , but cannot access OC options.
I had to update BIOS thro @BIOS because i dont have a floppy drive. ANY help or ideas ?????
« Last Edit: October 12, 2010, 06:26:27 pm by runn3R »
Re: UDR3 ver2 BIOS problems
« Reply #1 on: August 20, 2010, 06:05:48 pm »
Hi and welcome to the forum. Do not use @BIOS in Windows it is far to risky. Use Q-Flash in the BIOS instead. If you are unsure on the procedure check out our FAQ section here: http://forum.giga-byte.co.uk/index.php/topic,2441.0.html
fatbobuk
  • 73
« Reply #2 on: August 20, 2010, 10:07:07 pm »
Thanks for the info
Tried this method but still had problems
Managed to get into OC menus tho
Booted OK after some tweaking
Will try it out tomorrow properly
« Reply #3 on: August 20, 2010, 10:13:43 pm »
Please list all your hardware and OS for next time. ;)
fatbobuk
  • 73
« Reply #4 on: August 22, 2010, 07:35:19 pm »
Windows 7 64 bit
X58 udr3 ver2
6Gb Corsair Dominator ddr3 ram
Zotac GTX 480
Asus 8800GT
Core i7 930 with Titan Fenrir cooler
3 HDD's various sizes etc
Returned bios to FA ( original ) cause of problems with FB11 and FB16 bios's
I have tried implimenting them the other way aswell but major boot problems / issues
To boot it takes for ever to even detect the drives then goes into a boot cycle getting slower and slower
« Reply #5 on: August 22, 2010, 07:45:10 pm »
Can I just clarify that the motherboard is a GA-X58A-UD3R revision 2.0
fatbobuk
  • 73
« Reply #6 on: August 23, 2010, 08:12:39 pm »
Yes it is a x58a-ud3r Ver 2
« Reply #7 on: August 23, 2010, 08:39:13 pm »
I know that you are into overclocking and that's cool but I would reset everything back to the optimised defaults until you have cleared up any problems. Once you're sure that the system is stable you can start playing with the settings.
fatbobuk
  • 73
« Reply #8 on: August 23, 2010, 09:44:22 pm »
System runs stable at default with FA bios axcept for the disappearing ram
System runs stable overclocked to 4Ghz with FA bios except for disappearing ram
With FB11 or FB16 bios's the system will not boot or takes a very long time
It is now all at default settings with FA bios and running sweet except only 4Gb is usable out of the 6Gb
« Reply #9 on: August 23, 2010, 09:51:26 pm »
If you updated the BIOS now at defaults would it not be stable? I have only seen two reasons for your problem and those are either bent pins on the CPU socket or the BIOS needed updating.
fatbobuk
  • 73
« Reply #10 on: August 25, 2010, 05:47:37 pm »
Reset everything to defaults on BIOS FA
Booted to windows OK
Using FLASHQ updated to Fb16 BIOS
If it boots to windows it takes about 10 minutes
If it doesnt boot to windows if BSOD with PAGE ERROR
Once up and running everyrthing is good. 6Gb of ram and performance is good.
Have tried to BOOT 5 times now and 10 mins is the average
« Reply #11 on: August 25, 2010, 05:50:46 pm »
Is there any specific place it hangs on when booting?
fatbobuk
  • 73
« Reply #12 on: August 25, 2010, 06:32:31 pm »
Pauses before memory check
Pauses before disc/ide drive ckeck
Pauses before DMA update ? not sure if thats correct
Pauses Before Windows Starting to load screen
Pauses at Windows Starting screen
Once into WIndows it is great.
Non of this happens in FA Bios in default or overclocked
But same happens in Fb11 and Fb16
« Reply #13 on: August 25, 2010, 06:34:08 pm »
Have you got quick boot enabled?
Make sure anything that it looks for that you don't have is disabled too. ie drives, floppy, etc
« Last Edit: August 25, 2010, 06:35:39 pm by Dark Mantis »
fatbobuk
  • 73
« Reply #14 on: August 25, 2010, 07:06:09 pm »
not got quick boot enabled ?
